Ok, so setting base timing with factory ecu, you pull the "pill", rotate the dizzy to 14* ( for 93 octane) tighten dizzy, reinstall pill...how do you do this with ms/ts......everything ive read so far (had the pnp for a week now) says to use trigger wizard and set it to 20.....so the base timing is set to 20 $@%!&# degrees?!!!!...
Im confused....the car runs and drives, just not great
