351w or 460?
I've said it several times here. A 460 ( a good 460, like an old police interceptor engine) will kill a 351, only needing the mildest stuff to make a 11.0 drag car.
The car will require a transmission that is not readily available though, ( like a c4 with a removable bell to fit a 385series engine) otherwise you'll be relegated to a heavy assed c6 to get the job done.
In 95-97, I campaigned that engine in a street/strip car that I drove through the gate on M*T sportsman pros, and on the very first pass the car went 7.15 purely on the motor.
That car was an 80 notch, and the engine fit better than the stupid junk it came out of.
Was it heavy? Yep. Was it a pig in regard to stopping and handling? Yep.
But it was basically stock, with only a Cam intake, and headers. faster than any 351 in the same Configuration will ever be.
Reactions: RaggedGT
You can keep this same thread going for your 'build' . You already have a following and they will get notifications when you post stuff, just change up the title to keep it exciting like, 'stuffed in the engine, now where did I put that driveshaft?'
and pics, we like pics, but no cat pics, unless there are high flow fans or random beer with strange names involved.
Ok herr is where I am at. Heads were wp windsor jrs which I sold. It had vic jr intake and msd distributor(change gear) with xe284h cam(get different) and a holley carb (can not find numbers). I picked up a 351 out of a f250 that I am currently starting to tear down to the short block and wodering how swapping these parts on stock heads would do.
Plan is to get running so I can drive the car cause pointless to have a car sit. I am on a budget hence the title. I plan on saving up and going 408 with aluminum heads but that will take time. I have a spare block sitting for that.
Thoughts and coments are appreciated. I have not got to mess with engines in cars for awhile and never messed with ford engine. I added pics of broken block and I will get casting numbers off of other block tonight. I can not figure out what shocks on front. There are strange adjustables on rear cant tell what control arms on rear and has summit lowering springs. Rear is 8.8 was told trac lok with 4.10 gears.
You say I can edit the title. How do I do that?
