Suspension Bilstien rear shocks
Mustang5L5
Mod Dude
Feb 18, 2001
43,169
17,865
224
Massachusetts
I'm having trouble figuring these out. They are 94/04 shocks but that shouldn't matter. Not enough threads to engage the nuts.
Circlip everytinh bottoms out on
You can see the stackup minus the dust boot gives me 1/4"
But the spacer in the boot is more than that. So with everything installed I have no thread
I've pushed and pulled and rearranged but can't get a nut on these. All pics I find show this exact arrangement.
Both shocks do this
Would installing them in the car with the weight pushing down on them give you the extra room to tighten the nut?? Mount them on the bottom, guide the shock threads in the hole while letting the car down on the ground then tighten? Maybe the lower bushing will compress enough to get you the room you need. Maybe I’m totally wrong, or maybe I’m a idiot and you already tried that.
Can't get the axle to articulate that far up with the spring in. Would need to remove it and then jack the axle up. I kinda feel that if that's what I need to do then something is off
Those rubber bushings usually squeeze up a lot when you tighten everything up. Maybe you can pre squeeze them some by using a nut and bolt to compress them before placing on the shock. I don't know how much they will spring back but it looks like you only need a bit more to get it on. Good Luck
Tried jacking one side up all the way but it only lifts the car. I tried using the worn bushings from old shocks but they don't fit right but I'm albe to get it to squeeze down. Problem is when I go to swap the new bushing in it relaxes
This is what I got on both sides. Can't catch a single thread
