There isn’t really any rust. It’s just damage to the sheet metal that looks like it was from an accident. You can see it just to the right of the driver’s bumper bracket. The rear trunk support is also pretty mangled and looks like someone tried straightening it out before. That’ll get replaced too.Looks like someone may have patched some holes in the tailpanel at one time . I dont think that the pieces under the end caps can be bought seperat from the quarters . I will be pulling the quarters off mine soon and i can save them if you need them ,if you have to do the quarters new ones come with the new quarters.
Is the trunk floor bad enough to need replacing or can you just patch the rusted area?
So far, all the rust is just on the surface except for the floor pans and possibly some areas of the cowl. I wouldn’t need to replace much if it weren’t for the accident repairs and bad bodywork.
Edit: I will be needing those extension pieces if you have them or know where I can get them. I thought Dynacorn had the extension pieces separate. They do, but only for a fastback.
https://www.cjponyparts.com/dynacor...er-driver-side-fastback-1965-1966/p/3647FBWT/
