Hey guys I've just started on my 2000 Mustang GT after owning it for nearly a year (newborn came first) and have run into a sticky situation. The previous owner has installed long tubes and an H-pipe and capped off the EGR tube on the EGR valve itself. I can't tell from the top side if there is a spot on the headers for the tube to attach until tomorrow (my jack won't fit under the car, waiting for a friend to bring one by). From some simple searching I have come to the conclusion that you have to tune the car to compensate for an EGR delete (let me know if this is true or false, please).
Would it be easier for me to get the tubing routed to the headers or should I look into deleting the EGR? Thanks in advance.
ton of research also. I came upon so many different answers, the EGR only comes on when cruising/staying at same speeds/rpm for a certain period of time, EGR delete will make you lose about 2MPG, EGR delete will probably throw a EGR+O2 Sensor code(For me I had a o2 lean code), I have heard EGR delete can help reduce carbon buildup, I have heard EGR delete can cause detonation which I think is bull
