I have a 1995 mustang GT I'm am getting a few codes like mass air flow, air intake tempature sensor, I have the correct firing order,new spark plugs gaped at .052 and wires, fuel pressures good 40psi , I set timing to 10btdc and it bairly wants to stay running along with pooping/backfiring out of both intake and exhaust. When you do rev it up it almost has a stutter when reving, I've tried advancing timing to 14btdc and same thing. I know there's a little screw on throttle body to turn and adjust the idle rpm, as soon as I go below 1000rpm the motor shakes the whole car. I was told when I bought it that it does have a cam, I don't know what but don't think a cam would make it shake like that. Could a mass air flow cause that much trouble? And I replaced the air intake temp sensor I may need to reset codes to see if it fixed it.Any help would be appreciated, thanks
