Thats ok, currently working on a "drop in" instrument housing so no damaging the factory cluster. even have instructions for adding the fuel level to the MS without hacking any factory wiring.
Sorry to get (sort of) off topic - but the FTR brackets you have for your brakes - Is that all you did to install s197 brakes on the front of your car? Will they work with regular non-brembo brakes as well?
What did you do for the rear wheels? I'm wanting to put some dinner plates back there, purely for aesthetics.The ones that I got are the non-brembo 05-09 GT dual piston calipers. They are a direct bolt-on, but I had issues with mine due to the wheel that I choose being a smaller inside diameter than normal 18" wheels. I had to smooth out the top ridge of the caliper to have them fit without hitting the inside of the wheel.
Outside of that they are fantastic and was able to keep all the stock MC and Brake Booster including the SS soft lines to the calipers.
What software does the printer run? CAD, SolidWorks, etcBeen a little slow trying to get some progress done for the new enclosure. I have been doing "testing" on the machine to get the slicer program to give goo results on its prints. So below are some of the again "test" prints before working on the enclosure.
I also ordered the remaining parts needed to put everything together including power plug connectors, cables, and resistors and diodes. I have plans to get over to work on the enclosure 3D design this weekend, so hopefully should be able to do some test prints next week.
Looks like you are getting the hang of the software. Good job.I was able to finish the 3D model on the new fender badges for the car. Here is a picture of one of them printed.
They still need to be smoothed and painted, but this is one right off the printer.
What material are you using? ABS, ABSPlus, PETG?
Of course... For making sundaesCan you use a chocolate bar?
After more coffee?
Well I was going to say if you needed help lemme know, but sounds like you’re picking it up quick!Yes, LOTS more coffee, and then was told I have to do this work thing. Who would of thonk![]()
