What will RPMs be with 373 gears in auto
I have 327 gears in - rpm 1850 @ 65mph - any idea on rpm with 373 or 410s
So, let's just make this easy, though my engineering/physics mind would prefer all the data:
373/327 * 1850 = 2110 RPM
410/327 * 1850 = 2319 RPM.
The answers should be as accurate as your RPM estimate is.
I have 225/60/16 on stock pony rims - when tire change is needed , if I drop down in height a bit to a 55 or 50 it should give more off line torque ? It will harden the ride a bit with less air though and may look too short on tires - maybe a half inch drop in height would be nice compromise before I do gears ( 373 sound reasonable for daily driver with highway option )
It will have an effect on gear ratio and make it higher (number). Whether it will effect it enough to notice, I doubt it. It will, however make your speedometer off enough where you’ll probably notice that!
The tires, and or the rear end ratio do not affect the rwtq in any way.
The engine will make the same rwtq number with a 2.73 or a 3.73 rear gear set regardless.
