As part of my gathering of parts for my Scarlett Red money pit
I'm swapping out out the rear axle, doing gears, 5 lug and discs (Oh, upper and lower CAs too) Looking at the axle the stock diff cover is a bit of a mess so I was going to replace it with the same factory type cover. Now that I've looked around and stopped my head from spinning... What suggestions do folks have about what i should replace it with? I've seen this
lmr.com
for $110. It does not have bearing cap support but is all aluminum and has drain holes. I'm open to suggestions but don't want to break the bank.
Let me know
Mustang GT500 Finned Aluminum Differential Cover (05-14) 8.8" DR3Z-4033-B
Help your 2005-14 Mustang 8.8" keep it's cool with this GT500 finned aluminum differential cover.
Let me know
. So I've taken a look at a few of the recommendations and some others.I do have a question about these bigger covers. I assume they require more fluid, but I can't find any specifics on it. I just picked up a gear kit (ring, pinion shims, seals, etc) and 2qts of royal purple and friction modifier. Do I need to get more of both, how much, if I do?
