I’m back to doing the mad scientist sht that I thought I was done with when I decided to buy a “ mainstream” complete engine.
It seems no matter what I do, I’m gonna have to rig up something to make it work regardless of the engine I choose.
a 2jz uses a stupidly expensive IAC motor that bolts to the underside of the intake manifold.
As a direct Toyota replacement, it’s almost 300.00. From an alternative supplier,..about 100.00 less.
There are companies that are out there making adapter kits to mate a standard ford IAC motor onto the intake, but even then, it’s still 176.00 before shipping and tax.
One Seventy Six.....before shipping and tax....Seems to me, I have enough sht laying around in a freakin drawer that I can make this...
Let....
Me.....
See............
Yep!
* Before I show you this,..let’s all bow our heads, and have a moment of silence in memorial to the dead Monster engine, that was gracious enough to donate all of his reusable parts for the good of all the future little monster engines that may be less fortunate.
I had purchased the Ford IAC valve eons ago, so to me, this purchase is dead to me. The rest of the stuff was on the monster engine. The filter was one of the numerous ones I’ve went through trying to control the blow by, and the long tube was part of the oil return drain for the turbo. I’m quite sure the length of that thing will bug me, and I’ll go get a shorter one, but for the purposes of doing this with junk in a drawer....
Like I’m gonna spend 176.00 on a stupid little gizmo that can be made in the comfort of my own garage, using only a hammer and a pair of pliers...PFFFFFTTT!
I started mocking up the water recirculating system for the A2W inter cooler. This time I had to buy the reservoir, and I’ll have to buy the hoses again, ( cause I’ve cut the old ones up a dozen times using them as vent hoses for the huffin’,puffin’ till it blows itself apart old monster engine), but again,.....I got the rest of the junk just laying around.
in the pic, nothing is mounted, it’s all just laying there..The pump is one of two that I have that used to be what I used on V1 for engine cooling. I bought the red one after I fcked up the old black one when I tried modifying it, but the black one still works..
The dilemma when you use a stupid SBC water pump to pump water to the inter cooler is that it has 2 outlets..and there’s only one hose going to the inlet of the inter cooler. While I guess you could block one off, it just doesn’t make sense to me, especially
considering what’s in my drawer..
I mean, really.......who has so much -12 junk that you can take a standard dual outlet SBC pump, and make a merge to a single outlet?
No guesses?
Me.
There‘s irony in the whole A2W vs A2A thing here for me, considering I gotta find a place to mount the radiator that cools the water..You might question that if I have to go through all of this trouble to mount that radiator up front where I want to, wouldn’t it have been way easier to just mount an A2A unit up front instead...
Youd think.
But I’d have to ask you a question in return..
(stupid website only lets you attach 5 photos per reply)
