- Jul 7, 2005
- 1,563
- 1,110
- 164
I finished everything up for them this past week and have them ready to go now.Looks awesome, let me know when you're ready to start shipping them out, all plug and play and whatnot... I'll start saving now.
So question on this, how does the fuel, oil pressure, and volt gauge work on this? My ECU is the MS2PNP unit that was drop in on the mustang so I didn't do any of the soldering.
Yes to both, we can design any dash you would like.Would a Pimpxs also need the same type of wiring for the fuel level to work?
Any chance someone could make a dash that looks similar to a stock dash set up?
Fb famous- congratulations buddy, glad to see some orders rolling in and tons of interest in your product-![]()
The free version is loaded onto the unit, you will need to put in your registration code to unlock the full version. So yes you will need to purchase the upgraded software. It can be loaded onto up to 3 pc at a time.If TS comes with screen do I still need to pay for it when ordering my Pimpxs?
We are working on that right now, however the release date is to be determined. It still has to go thru testing.so I just found out about this dash and I’m very interested in it. I a little confused, and can’t find any information stating but this dash will only work with aftermarket eco? Will not work as a stand-alone?
I will definitely have my eyes out for it then! Thank you for the response!We are working on that right now, however the release date is to be determined. It still has to go thru testing.
Both inputs will be taken in through the options port, oil pressure to the knock input and fuel level to the external map pin. The fuel level requires a 5v pullup, this is supplied in the kit. The oil pressure can be achieved with a 3 wire transducer wired into the baro plug on the firewall with the wiring extended down to the sensor location. The baro wire will then need to be jumped over to the options port as it is not tied in to the ms2pnp. The case on the pnp will need to be opened and a few jumpers moved, the external map will also need a long jumper that we can provide in the kit.
These instructions will be provided as well. I can even try and get pictures.
The needed items to build the fuel level circuit.Rereading some of this and was wondering when you mention stuff being "supplied in the kit" which kit are you referring
to?
