Has anyone used the LED lights for blinker and high beams?
Yes, you can wire in LED lights into the factory harness. You will wires the (-) to ground and the (+) to the indicator light on the factory harness since its a 12V+ when active.
Very curious about this dash myself, they look really good! Is there a kit for the SN95+ cars? I think 94-2004 use same cluster size/design, just different wiring? Any option for the other "idiot lights" these cars have from the factory? ABS, Airbags, etc?
How is glare when sun is out etc?
Have you installed led lights in yours or have pics of anyone elses? I am wondering where some have put the led lights. How do the led lights
mount that you offer on your site?
I was looking at a wiring diagram for the factory wire harnesses and it looks pretty straight forward
to tap into ground and blinker/high beam positives. My question is there is 12v input wiring can those wires from the
factory harnesses be used to power the digital dash?
We are actually on ver.2.5Is there a Gen2 DD EFI being working on?
Like Steve mentioned above the Digital Dash is currently on V2.5, but are working on V3 right now to meet the needs many have asked for. We have upgraded to large capacity 3D printers to allow for one piece bezels, integrated all main components onto a single pcb board, and upgraded to latest computer and OS.Is there a Gen2 DD EFI being working on?
0V = -28.69What were you guys using for values when configuring a generic gauge?
We will have 2 versions of the dash... the standard we sell now [with upgrades] and a new unit that will have inputs and outputs.This is great news! Excited to see how this works. So with V3 would your fuel level/high beam/turn signal wiring go to the back of the dash? Is there a tentative release date on V3?
You don’t need a canbus connection to run one with a pimpxs. It just connects right to the tuning cable.Was thinking about this more and realized my Pimpxs does not have a canbus connection...
it does, its on the options port. The dash in its standard package form uses a serial connection [same way you connect to laptop]Was thinking about this more and realized my Pimpxs does not have a canbus connection...
