Well,...another day gone by...
Turns out ( evidently) that the cranking log that I’ve sent to the powers that be has turned out to “not be suspect“.
MOF,..Matt Cramer said that my composite logger looks “great though”,
So,...I’ve got no reason that my sht won’t start,......nonetheless,...it just don’t....start..
I'm thinking a gallon of gasoline,....and a match.........will fix this.
I feel like you’ve been here before?
  • Wow
  • Haha
Reactions: HotFox and RaggedGT
Tomorrow i’ll try another start attempt. This time Steve will be online. The only things i’ve changed since my last attempt is that the VR sensor wire now runs inside the top of the passenger side front fender, instead of right down the middle of the engine.
There was a hidden trans leak that left a decent puddle after cranking...I must’ve hit one of the two male -6 fittings line fittings with a hammer or something when I was cutting off the bell, or making the adapter plate, cause that top line fitting was mangulated. ( Had the engine started and ran like it was supposed to,.....the puddle would’ve been epic.)
You remember the WTF bell housing adapter stage.....Where i decided to cut off the 4r70w bell,...cut notches in the front pump, and make this goofy ass adapter to allow the A340 bell that fits the 2 jz to bolt on....
( :nonono: phuckin photobucket....they claim that this is a “small” watermark in the corner of the pic,...as many photos as they have of mine that are now being stored, they wanna charge me 13.00 a month to access them.....they can go phck themselves)
Anyway,...when the engine was “ old monster”, and noisy as hell, who knows what other clicking/clunking/whirring noises were also going on at the same time.
Now that I have the new monster engine,...and despite the fact that it has only chugged and choked for a few seconds......
I got a whirring noise now.
The suspicion is that the starter is hanging and remains engaged while the engine runs. Except, every time that i’ve gotten under the car to check that, ( after the engine has stopped) the starter is where it’s supposed to be. So,...maybe it hangs while the engine is running, and retracts when the engine stops.
A potential bad thing I know, but the adapting process has nothing to do with causing it. The starter bolts to the block.
Nonetheless....I changed stuff relative to that.
What I changed was the flexplate, and it’s spacing off the rear of the engine . ( Both very relative to the problem). I guess if I have to, I can shim the starter away from that, but i’ll have to make that shim. On the other hand, I could just need a new starter..it is the stock unit, and it is.....like the engine........20 years old?
FINALLY! Just when i was completely whipped,.... :nonono:
Me and Steve had bruises all over our heads from crashing them against the wall. From 10:20AM, till about 3 PM, after numerous fails...the thing wouldn’t start, and run long enough to do anything. Trial and error diagnostics proved to be frustrating, as one time we had something, and the next time we didn’t. I’m spitting nails by the end of the session, and if not for him being on the other end of the line, it would’ve been an utter and complete meltdown for me. I was so mad, i cussed myself and cursed the day i ever ever considered an engine that relied on a cam and crank sensor. We both give up.
We deduce that i have a sync loss issue stemming from the VR sensor, and he suggests that i buy a superior VR conditioner that might help the problem. I agree that nothing can be done until we solve that problem. He points me to the item online, I order it, and that’s that.
Until I read the fine print.....
The estimated ship time from Canada for this thing was 2-4 weeks.
I email the guy and cancel the order.
Now i’m ripe....i’m so steaming mad i’m actually entertaining bailing on the entire project,.......But decide to give ol‘ Google one more chance to help me...
And there‘s a guy that saying he fixed his issues with a single,......stinking,.......10ko resistor installed in series on the wire coming off the cam sensor.
I figure,...What the hell....i have the resistor, I know where to find the wire....i splice the thing in.....and turn the key to start it.
And THE FREAKIN THING STARTS,...AND STAYS RUNNING!
it ain’t right yet,..it’s not tuned. it’s got a small water leak,..but..
IT FREAKIN RUNS!
And as a footnote to the above...
While trying to start it, and now that it’s running, there was a decidedly ominous metallic whir coming from somewhere. Originally, i thought the starter was hanging, and I was hearing the thing spool down after it disengaged from the flywheel when the engine died/ stopped.
Once it was running long enough to actually slide under the car with the engine running, i discover that the starter was where it was supposed to be........i.e. NOT still engaged into the flywheel.
Yet,...there that noise was,....a metallic whirring....kinda like the noise you’d expect from a bearing no longer being lubricated.
Thoughts wandered....” I put a new front pump bushing in the transmission,..What if i didn’t line up the lubrication hole, and now the converter hub was running inside that thing without the benefit of proper lubrication?”
That notion requires this dude.:eek:
Removing the transmission in this car is exactly the same as monster V1.0.....The whole fckin mess has to come out.
I shuddered at the thought.
The one constant was that the whirring noise didn’t stop when the engine did. A definite plus when considering that it might be the converter. Cause just like the engine,..when it stops spinning, so does the converter.
But the turbo don’t. That dude could have a bearing failing...after all...it was only a 269.00 68mm Chinese turbo.....How long are these things supposed to last anyways?
I could live with having to replace the turbo if i had to....
I restart the engine on a mission...before i even can consider getting it running right, if i have to pull that bitch back out again, i wanna know tonight what it is BEFORE i get wakened by the 3AMD,.....
I get under the car...now actually quiet enough to hear stuff as opposed to the previous noisy ass tractor engine.........
And it reveals itself to me.
The engine is now pleasantly quiet, the whirring noise can be heard over all of it. At the rear of the car....
Strapped to one of the two rear mount radiators....
One of the two 10” fans...is howling away,..it’s bearing no longer doing what it was supposed to be doing,..and is now pissing and moaning, and making a whole bunch of racket......whirring away...
This was one of the original fans that made up the cat sucker...probably caught the brunt of the impact when the cat got sucked against the radiator...and was now....giving up the ghost.
R.I.P. Cat sucker.
So,....i get online,...... search 10” cooling fan.....Amazon has two...with mount straps,....for 34.00 bucks.
Ordered.
Until it gets here,..i’m cutting the wires to that fan....
I got no more whirring.
R.I.P. Cat sucker.
Ordered.
I am certainly glad that you got it running and then found the odd noise.
It seems that now would be a good time to buy a gizmo that turns your smartphone or tablet in to an oscilloscope... You could watch the electrons dancing around and capture a look at the one who was out of step with the rest...
  • Useful
Reactions: General karthief
It smoked pretty heavily towards the end of the start up. I'm hoping that it was oil/grease from the heads, oily crud in the exhaust, from the death of the old monster engine, and just because it's a brand new engine.
It was white smoke...I didnt go back there to take a whiff to see what it smelled like though.
I hope I've fixed the t-stat housing leak..if not, its gonna require something else be done to fix it. .I now have another oil pan seeping leak,...JB weld to that rescue,..and the intercooler lines need to be tightened at one of the unions...
If it's not smoking for any bad reason, and is just one of the listed ones, then Thursday will be the next time i can mess with it. It needs to have all of its ASE/WUE, acceleration enrichment curves re-enabled.
( we turned them off, just trying to get the thing to start.)
If it dont stop smoking, I could have a bad ring in the cylinder I thought was weird when I installed it, or maybe a ruptured diaphragm on the vacuum modulator that is in the transmission, and its sucking trans fluid...I'm just hoping it's just initial start up residue.
That's the strange thing, the inputs looked perfectly fine. All nice square teeth and in the correct number. Only thing I can figure is the resistor knocked down the voltage that was likely causing the freakout.
Now all we have to do is turn the tires over, until they make smoke.
Only smoke that matters is tire smoke. Don't worry about the rest. And I thought the friggin teletype was a recording of the original monster engine starting and running until I realized it was really a teletype.
:oops:
That freakin obnoxious 3AMD.. :nonono:
You gotta know that if I think there is something bad wrong with that engine, He’s gonna pop in, and wanna sit there and obsess over what might be wrong with something I did ( or didn’t do).
Anndd just like clockwork,..there that little mutherphckr was...sitting quietly on the corner of the bed.
”PSSSTT! You awake?.....Hey! we need to talk about this smokin thing the engine was doing”.
So i have no choice....I have to lay there and listen while he goes on a quiet little rant ( because he doesn’t wanna wake my wife) about this and that...worrying about this bad thing, or that bad thing that could force me to remove the entire engine.
He usually blathers on for about and hour,..and then when he goes to the kitchen, or the bathroom, i slam the door shut, and start thinking about things like Fargo ND in the middle of winter....basically locking his little ass in a different place.
Sooner or later,...he’s gone, and i go back to sleep.
But,....since I don’t want him to come back tonight, i have to be sure to restart the engine, and let it run for a minute to be sure it is either gonna smoke, or not.
Thats what i just did...
I got no smoke.
Choke on that 3AMD.
That's great Mike ! I figured it was residual crap in the pipes but didn't want to be wrong. Just crossed my fingers and hoped for the best.
