Need help tuning megasquirt with kenne bell supercharger
Memo302
Tijuana
Hi i just instaled a kenny bell supercharger and cant get to make it idle correctly, im still learning how to use the tunner studio software, the basics i consider that are right like the timing, injectors that im using.
I would apreciate any help i can get.
I will upload mi tune in just a moment
I have tride to stabilize the idle in close loop but havent been able, and wen its coold its struggle to make it idle without puting the foot on the gas, when i put it in fixed timing and open i was able to stabilize playing with timing and the ve
Timing seems low for blower setup. From what I've found is that blowers need more timing due to the increased air flow. Also, Accel enrichment and warmup enrichment seemed to be cause alot of issues for me. Definitely timing is probably what needs to be adjusted. I'm still figuring this out after 10yrs. Reply back with update.
between 20-25 seems to where should be around idle and setting the fixed timing 20 made it so much easier. There's a guy BlackFox on internet-youtube that helps out. Few others mostly on dyi megasquirt page on FB.
Boost stock timing table image didnt work out well for me. The AfterEFI class tuning worked for me the most which Scott Clark EFI Tuning Trainer / Specialist!
  • Timing Tables (5).pdf
I am BlackFoxEFI.
I would not run any of those tables personally but each build has a different timing requirement
Just what I've tried my 2 cents ;/
Well some incorrect generalizations have been made, if it were as simple as setting the timing near 25 people would not have an issue getting idle correct.
FWIW my 393 with a blower cam and 9.5comp like to be around 16* at idle.
Your timing under boost is very low, lots of power left on the table. With a blower .75*per psi is plenty safe with most heads. Unless you are running something more efficient like a 11r, those heads and similar it's best to use an LS timing curve.
