Ford Racing Z2363 Crate Engine Build
FYI, a lot of the sensors and such that LMR sells is parts-store brand sensors that LMR marks up. You might be able to save 50% by just going to your local autozone or bulk-ordering it from Rockauto.
Of course, in the grand scheme of things, it will save you 0.001% of what you are spending
I've said it before, I don't understand why buy common parts, sensors, senders, gaskets and such, from LRS or any 'speed/restoration ' place, if you're spending that kind of money you should spend some time researching price of parts, save a few dollars here, a few dollars there, it will add up.
Senders/sensors
LRS $60+
Rockauto $40 + shipping
there are discount codes with rockauto that most times cover the shipping,
you are spending a lot of money, shop smart.
Just an opinion from a grumpy old man
Reactions: mikestang63
Senders/sensors
LRS $60+
I completely agree. I'll go into this build with confidence now though that I have the right parts AND all the required parts.
I've said it before, I don't understand why buy common parts, sensors, senders, gaskets and sucharket , from LRS or any 'speed/restoration ' place, if you're spending that kind of money you should spend some time researching price of parts, save a few dollars here, a few dollars there, it will add up.
Senders/sensors
LRS $60+
this may dound crazy but i would rather install used FORD OEM working sensors than most new store brand ones. When I go to the JY i make sure to pull the IAT, ECT, TPS, starter solenoids and other do dads. IMO they work better and last longer and are dirt cheap. Same for water pump bolts, pulleys, brackets, window motors, door poppers, interior switches. distributors, TFI;s harnesses etc. these cars are 30 + years old and you will need to have backup/replacement parts around as they ain't cheap anymore.
Reactions: Habu135
3.73. Nitto 555R for now. I'll see how bad it is.
I would like some input on the 2.66 versus 2.97 T-56. The transmissions differ throughout the first three gears.
I was more wondering about the actual size of the tire, because a 2.9X first gear feels a whole lot different whether it’s a 26in or a 28in rear tire, with decently low rear gear.
I’d probably just recommend the 2.66 first gear trans. If you look at modern driveline they also have the wide and close ratio transmissions, but you can choose different overdrive ratios which is nice.
Just measured it. 24" height
Remember, it's a 255/40/17
Just playing devils advocate…
Reactions: Mustang5L5
I met with my mechanic last week and we spoke tentatively about a mid April car drop off which means I would have to start buying parts fairly soon due to logistic (supply chain) challenges.
I appreciate the push toward a Coyote (modular) based engine. Honestly, it would be easier in the long run due to CARB compliance and room for growth, but I feel the draw to keep the car pushrod based and want a build it and drive it car. The coyote swap is a whole thing with adapting a modern engine to a mid 1970s design, and I don't have the patience anymore after two years to resolve long standing bugs.
Checking LMR, it appears that a Gen 3 Coyote w/engine module and 6 speed trans is approx $1k more than the Z2363 + T-56. It's close, very close as I'm not including the required k member for the Coyote or the different exhaust.
