Fox Speedo Sitting at 12MPH
Jamesmcga
26
Atlanta
I’m guessing this is a sign of a jacked up dash… any other things could be causing this?
Does it operate?
Since the guage face has been replaced, the needle has been removed. The stock guage has a needle test with a tick mark slightly under it. You position the needle so it naturally rests pointing to this alignment tick. You then lift the needle up and replace the needle stop.
I have those same guage faces. They never installed the stop. All the 140 and 85mph guages have the stop. The motorsport/SSP 160mph does not.
With the stop removed, the needle naturally wants to rest somewhat over the alignment tick.
Since your missing the stop, you won’t be able to use it as a rest. You’ll have to ballpark it somewhat below 0mph and live with it. Or find a needle stop
The tachometer would sweep? All those guages are seperate and can be replaced individually. So if the tach is bad, it can be replaced. The issue however is the guage faces cannot be easily transfered without causing potential uneven illumination due to the glue.
It might be best to buy a new 90-93 140MPH cluster if you have tach and speedo issues
No the actual speedometer would sweep.
I’m not even sure where to look to find an actual speedometer replacement, I have found a few instrument clusters online.
So what about getting the speedometer cleaned (everyone needs a clean Speedo) or repaired? I no longer know of local shops, but not everyone who knows how to should have yet passed away from old age.
