Foxbody new edge k member modification
Has any one ever modified a foxbody k member to fit a 4.6 cobra motor? Long story short. I was doing a 408 stroker but I already have a 4.6 forged with a kenne bell. It would be so much cheaper for me to just go this way. I already have a push rod maximum motorsports k member or else I'd would just buy the right one.
Probably easier to sell the pushrod K-member and buy the correct mod motor one.
The mounts are different, so you'd essentially need to cut off the pushrod motor mounts and jig up the mod motor mounts
The mounts are different, so you'd essentially need to cut off the pushrod motor mounts and jig up the mod motor mounts and weld them in.
Yeah I hear you. I was just hoping for an alternative due to k members popping up everywhere and never being sold. From what I've been seeing at least.
Don’t know if this helps but I swapped about 3 years ago a 4.6L 2V from a new edge in my 90. I used the new edge’s k member. Everything bolted up like stock, just had to open up two of the holes that go underneath the firewall.
  • Useful
Reactions: 7991LXnSHO
