Haven't gotten around to it guys, sorry. Work is kicking my a$$. I will for sure come back and have an explanation when I fix it. I just need a free/non-exhausting day. I'm gonna figure out where all the hot wires in the fuel pump relay are and go from there. I probably have things hooked up to a constant hot wire which keeps the pump on. My signal wires trigger the relay(s) every time but I'm hoping to remove the factory relay and just use the one that came with the painless harness. Right now I'm running both relays so I don't mess up the inertia switch routing lol. I haven't deleted any wires. Just added a "fuel pump wire" that I believe is a signal wire. It's been a confusing process but I'm determined to figure this little issue out. It's been a while since I asked the question but I won't be like every other forum that leaves you without an answer lmao.Well??
Don't just ask and run!!
tell us what you found.
