Complete shut down w/code C-18
You might have already covered this but check the power and ground wires on the 60 pin ECU connector. Mine had a issue where you could just touch one of them and the car would shut off. I ended up buying a new 60 pin connector and swapped them, tightening each physical connection as I moved it to the new connector.
Thanks Dan
I feel that at this point there is a list a mile long of what this can be and much of it is out of my range of knowledge or skill and with the winter basically here already in my area with no garage to work inside of, I made the decision yesterday to stop driving my mind wild in trying to figure this out by reading all night my Google searches and playing with things randomly that I honestly don’t know 100% what I’m doing. I am going to sit tight and wait until my December appointment with the shop I picked out and leave it in their hands. I’d hate to start running out as the general says buying parts and switching things more than they have been already and then still have to hand over the car to the shop and explain what I messed with and wires I pulled etc. I’m just frustrated at this point so I’m going to take this off my plate and leave it to the professionals. It’s going to cost me but when it’s fixed I will be super happy and will have information to share with you all. If it were warmer outside it would probably be a different story but my hands were going numb yesterday just doing an oil change and rear shocks/quads. I can’t imagine working in the cold when I’m just guessing and don’t know what I’m doing or looking for. Hopefully I will have solid info for you all by the end of December. Thanks everyone for trying to help me!
I had the same problem with that 89 f150, everybody kept changing stuff and when it still acted the same they didn't change it back and that created more problems, I had to change everything back and test one thing at a time. I finally got it to run fine with the exception of a sudden ruff running, then run good situation, that truck has a problem that was there before the engine change so I gave it back to the mechanic that installed the engine. Now he is back to changing a bunch of stuff that has nothing to do with what the issues are. He just called a little while ago, my first question was 'did you check codes?' His answer was 'those computers don't tell you nothin'. He has worked on newer stuff that basically tell you how to fix it.
I hope that shop gets it straightened out for ya, Keep us posted.
Thanks General! I hope they figure it out as well. I have confidence. That’s an unfortunate story about your F150. Sorry to hear about that. I know what your saying about nobody wanting to pay attention to the codes. It’s frustrating. Wish I knew how to address some of this stuff myself but I’m glad this place is going to take me
In and do their best. I will keep you posted. Thanks for your help with this this and my other past issues!
That’s because troubleshooting is a dying art and most folks just fire the parts cannon at a problem until it gets fixed.
  • Agree
Reactions: 1 users
UPDATE:
Problem SOLVED
It was two separate issues causing the stalling:
#1 Failing Computer
#2 Bad distributor
So it was discovered that when the computer was tapped/shook/etc, while idling or driving that the car would shut down. When the computer was swapped out with a known working computer that issue was resolved meaning the computer would no longer stall the car when it was moved around, shook, etc... However, the car would still stall on its own while driving... The distributor was removed (brand new China part) and swapped out with a known working original Ford Motorcraft distributor. The car then ran perfect! So between the delicate computer connections (failing capacitors inside) and the aftermarket distributor, both issues were causing this problem. The car is running perfect again and no stalling issues at all after driving all day today. To say I am happy again would be an understatement.
I hope this helps others in the future that are experiencing the same problem. The cause of stalling can be many different things but for me it ended up needing the computer to be refurbished and a genuine Motorcraft distributor and not some junk aftermarket replacement. You guys called it right! Lesson learned and I thank all you guys for all your input and expertise and especially the ace of a mechanic(a) that figured this out for me and quick! Hope this helps anyone else someday.
Reactions: 4 users
I’m still down gents....... it’s been 2 months and problem still not solved. I had several very knowledgeable and competent smart mechanics and fox body enthusiasts play with it as well as myself for what I was able to do on my own but still no luck.
I will have an appointment with a very respected shop thats an hour from my home next month. I have a great feeling about this place and are excited to get someone else’s arms around this pony. I can’t wait to have her back in fine running condition.
I just thought I’d drop a quick update in regards because I’ve been dark for a while now. Be well guys..
What gears does she have?
