02 Black Gt said:i have deleted the cruise control in my car you have to disconnect the all the 2 bolts holding it on inside the fender. you aslo have to remove the the throttle cable that that is associated with the cruise control then once you have done that you can disconnect the wiring from inside, there will be a box on the left hand side of underneath the dash. unplug both of them and take that box out. then there us a rubber hose that goes right up behind the brake pedal that u can see if u just look under the dash and disconnect that as well then u can pull everything out from the front of the fender. take a look and you will see exactly what im talking about if u have any other questiions email me or PM me. i should have some pictures too that may help.
I have a question if this is ever seenRick, can you PM the Email? Hotmail is a cvnt! I got other emails, but not yours. You and I have trouble sending and recieving emails sometimes for some reason.
hey how's it going fyi I'm a Yankees fan from Massachusetts lol how did u make out with removing the cruise control and I'm trying to block the EGR tube that leaves holes in the heads I'm trying the cut and flip of the end parts off the tube but it leaks air still thank you for the reply I know it was a old post I'm new to mustangs it's my first one
I have the inserts I'm trying to figure out what to use to seal them in I've got a few different answers I'm leaning more towards red thread lock #271 but if u used something different and it worked let me know I've never done these before I got them in 4 or 5 turnsyou want thermactor inserts for that. For the cruise control, I really don't remember it was years ago. I removed it and threw it away, don't need it.
