Monkeybutt2000
Mustang Master
It's not,heck my local O'Reillys sells the valve lapping tool. I'm sure Youtube is full of how-tos.Garage valve job - that sounds very technical. Where do I read about how to do this?![]()
Thank you for this. I will do all of it before next steps. That said, I know the distributor, what TDC means, but not how to do any of those. I will start reading now.Bring it up to TDC, mark the rotor position on the inside of the distributor and mark the distributor flange and the block, I use a chisel to score a mark.
I see your point, anything that can be used to 'feel' the piston move can be used, keep in mind the area between the piston and the head at TDC is small so the object has to be small, so as not to jamb between the piston and head.The long screwdriver thing makes my OCD go loopy. I like a thin dowel rod,or something else that won't potentially scratch.
Pulled all the plugs. Looked good I think, with only #8, the last one at the bottom of the pic (driver side closest to drive #8?) looking white (pic at bottom)You're fighting a compression stroke, pull all the plugs.
