Top loaders and OD
WORTH
Nov 18, 2002
2,166
44
98
Cape Cod, Ma.
Have a toploader out of a '68 GT, are there any choices around to add OD. Been away from cars for quite a few years was hoping something is now available. It's actually going to end up in my '55 T-Bird.
Ya found the GV unit, but it is too large to fit in my '55 T-bird, so I have a different plan, going to try and find a wide ratio top loader and swap the rear to a 9" with 3:10's, ;should give me about 67mph @2500rpms on 28" tires. Does anyone have a wide ratio they would like to sell or trade for my close ratio?
Ford made a transmission in 77-78 that externally looks just like a top-loader but is actually a 3 speed with its 4th gear being an OD. I wonder if that would work? If so, here are some tag numbers:
RUG BP
RUG CA
RUG CD
RUG CL
RUG BP
RUG CA
RUG CD
RUG CL
Real Mongo, you evil bastard, do all the right parts still shake? Somebody tried to take my Life a couple of times in the last few months, so I got delayed on all my projects. But I believe I have it under control now. As for the '55 BIrd, I did buy a wide ratio top loader for it, k had my local drive shaft shop swap the slip yoke, and add a few inches to the shaft,, set up a 4 speed to line up with the original hole in the floor and test fitted her. And I actually looked at the rear end and figured it is a Dana 44, ( got a lot of missinformation before), and I can put 3.08's in her. So that will take care of the Bird, and I liked it so much I bought another one for my '65 E-Pup 200cid 6er and will do that after I get the bird on the road. This is the setup for the Bird.
I'm going to need to find a drive shaft shop myself. I changed the yoke on the 1965's differential and need to have a shaft made up with the proper rear yoke.
