Progress Thread Monkeybutt2000's 89 vert build thread- Back on track
Been a minute since an update. My side hustle kicked in so not much free time. I did get the full Performance distributors kit for the Fox. Was getting a miss at higher rpms,and with the OG 34 yr old dizz figured it was time for an upgrade.
Reactions: 1 users
I would rebuild or have rebuilt, your OEM distributor and put it on the shelf.
I also wish I had a dollar for every aftermarket distributor nightmare story I've heard about EFI Windsors.
Reactions: 2 users
I can attest to this, have blew 5 of those Duralast units in just a few months.
Winter "upgrade" time. Mocking up the Focus fans,fit pretty well just need a little trimming on some plastic. Going back NA, the turbo setup has just been a giant PITA for me,over it. Already have BBK longtubes,a Mac Prochamber I've had fof years,and an Anderson power pipe. Need a cat-back and some injectors and it'll be ready next season
Reactions: 1 users
If you want another Power adder without all the fuss just put a s trim on it . Pulley it to make 12-13 psi. Make sure you’re alignment is good and enjoy it
Reactions: 1 users
Got the longtubes on today. Pretty simple install. Passenger side dropped right down through the top no problem. I loosened steering rack and pushed it forward then removed steering shaft. I slipped it in from the bottom and my girl slid the flange over the guide studs I pre-installed. Whole process was less than an hour.
Reactions: 4 users
On a side note: Some of the best car advice I've seen from a Fox "Toober" in recent memory:
If you want ceramic coated headers, buy them uncoated, install them, beat the :poo: out of them until they fit perfect and [then] have them coated. :D
I mean, that's usually one of those things you just don't learn until you've done it but pricewise, the out-of-the-box solution looks attractive.
