Engine Block identification help
pindude80
200
67
38
Cincinnati, OH
Hello all, I recently bought a 1988 Mustang GT. It has a cracked cylinder wall.
I am trying to find a good short block. I ran across a full motor but I'm not sure if it is a roller motor or not. It definitely does not have a roller cam because the firing order is standard.
I got the casting codes located near the starter. Does anyone know what year engine this is or if it is a roller?
That number highlighted there is the date code. Can you read that?
I believe the E7TE block was 87-90. In 1991 Ford started using the F1SE block in the 91-95 Mustangs and other vehicles.
Went and picked up a '97 Explorer GT40 engine today. 120k miles, pulled oil pan, everything looked good then I looked over and saw the engine mounts. one had a broken bolt and the other three were broke off. I guess it came out of a vehicle that took a hard hit in the front and it snapped them off. Luckily the junkyard is cool and is returning it. They have another one but it has over 200k miles :(
Reactions: limp
Are you worried about block damage with the one you had? or just did not want to deal with removing the broken bolts from the block?
It has one broken bolt- not worried about that. I'm not worried about block damage either. 3 out of the 4 motor mount ears were sheared off the block. There is no way to bolt down motor mounts. I ended up buying it from the junkyard as a "core" for $200 since it is a full GT40 motor from oil pan to intake. I thought about taking it to a local welding shop at some point to see if they are able to repair it.
OK, I follow you now.... Not good......
