Electrical No fuel pump prime or start
AnthonyA1234
5 Year Member
Aug 17, 2020
674
111
63
Florida
I took my car to get painted and it ran great. Now I got it back and the fuel pump is not working… Any tips on how I can trouble shoot my way to finding the problem? I did a wire tuck so the pump relay and all those wires are all pretty hard to get to now. However I took the front bumper off and reached inside the fender where I hid the relay and I feel and hear it clicking. What else can I check?
Inertia switch is also good
Rather than repeat some things, check this out
Should be a good place to start
  • Useful
Reactions: General karthief
I attempted jumping the test port but im not sure if im doing it right. All I had was some extra wire so I stuck it in the port and touched it to multiple ground locations with the key on and nothing happened. Am I doing something wrong or is that just the result of the test?
Behind the bumper cover, under the car and just above the fuel tank. This one:
Which you can see in the very upper center of this picture:
So good news I have power at that fuel pump connection you told me to check. Should I just order a new fuel pump and filter and knock that out or are there any more tests I should do to check if it’s anything else
