Resolved Stumble issue upon acceleration (1987 GT)
Before I try another volume test, I'll do some math with the results of my first volume test.
I got 75 grams of gasoline in 15 seconds.
Multiply by 4 = ~300 grams of gas per minute
300 grams of gas per minute x
Maybe a dumb question, but have you verified the available voltage at the pump during the test? Not, what does it read with you test it static, but the running voltage? I found an insufficient ground problem testing a pump that way. Since these vehicles are so ground sensitive, I offer that as a test input that might point to a different problem. Just another thing to test before replacing the pump.
Hello, I have not verified the voltage at the pump during the test. It is possible that a ground could be off? Thanks for the idea.
Anyway I can test the running voltage without removing the fuel tank ?
Reactions: Mcmahst
You can back probe the wire in the connector behind the rear bumper, under the car, and just above the fuel tank.
This is the connector pulled apart:
You can see in the very upper center of this picture:
My guess is the fuel pump wire colors will be pink/black for positive and black for ground.
Reactions: Mcmahst
Did you replace the distributor trying to fix this problem? My 89 did the exact same thing yours is doing, my brand new distributor was the problem. Put the old Ford one back in and it fixed a multitude of issues I was having.
Reactions: FoxDude87
I did recently have a new distributor from LMR installed ( it cost me like $80)
I still have my old distributor. It's the original Ford Motorcraft.
I guess It's worth a try. What exactly was your 89' fox doing And what multitude of issues did you have?
I'll laugh if that's what's been causing my grief and confusion
Does the old stock distributor still have the TFI module on it? If so I would remove it and use some brake cleaner to remove the paste off the back of the TFI and the surface on the distributor. Then apply some Arctic Silver 5 AS5-3.5G Thermal Paste to the distributor surface and reinstall the TFI. This will ensure that the TFI has good thermal transfer to the distributor to keep it cool. I have seen where the thermal transfer was not good and the TFI module would be intermittent due to the heat buildup and then eventually fail. Link to the paste on Amazon:
Yes. The old original distributor still has the original motorcraft TFI module. I also have some thermal paste I purchased from Best Buy not too long ago. It's not the Artic Silver 5 brand you speak of but I think it should be good enough.
Hello everyone. I'm new to StangNet, so I hope I can find a solution to my driving issue.
I have a stock 1987 GT convertible Automatic 5.0 (speed density) car. I've owned it for more than 12 years with my fair share of ups and downs and I love this car.
It has 66-67,000 original miles on the clock and I'm having an acceleration issue. It seems to stumble (maybe misfire?) On moderate acceleration right around the 1500-1800 rpm range.
It does this when the engine is cold or warmed up. If I get on it, the rpms will drop up and down just slightly, Then she will smooth out.
Recently a New distributor, cap, rotor, motorcraft TFI module, plug wires, motorcraft copper spark plugs (gapped .054), Ignition coil, 3G Alternator, starter + starter solenoid, IAC, TPS (set to under 1 volt , about 0.72 volts. WOT is 4.25 volts)
EGR valve w/ EGR position sensor, PCV valve + grommet at rear of engine, ACT sensor, ECT sensor (coolant temp sensor), NTK oxygen sensors (no catalytic converters), fuel tank, fuel pump, fuel pump relay and filter.
Checked for vacuum leaks with a smoke machine and didn't find any leaks.
Idles good at around 750 rpm in drive. Idle is close to 900 rpm in park.
Timing is set to 10° TDC and it was set when the mechanic installed the new distributor, IAC and TPS.
It seems to have good fuel pressure when I checked it last. It does this almost every time I drive it now. If I'm steady on the gas, it's less likely to do it. And I've noticed it will stumble a bit more if I'm giving it more gas driving up a hill or inclined road.
Any ideas on where I should go next?
FPR ? Injectors? Transmission ? Lol
I looked through some of your other posts as well.
Thoughts: MAP sensor or a leak in the inlet someplace (previously mentioned). Also, look carefully for any vacuum lines that might be [sharing] a vacuum source with the MAP. If so, find a way a run the MAP sensor directly to the intake without any taps or Ts.
Also: Are the parts you swapped a response to this issue or did issues come after the parts swap?
I will look into the map sensor vacuum line or lines sharing that vacuum. I will see If I can run the vacuum directly to the intake by itself. Then take the car for a cruise.
This all started after a new distributor was installed. When I took car to the mechanic, he stated the distributor is good and is working as it should. He mentioned that I needed a IAC and TPS.
The car idles good , runs fine while driving to a degree but then seems to stumble intermittently.
RPMs will drop ever so slightly when I give it some gas while crusing around (or going up hills)
Almost "feels" like a misfire or fuel delivery issue.
If I get on the gas real good, doesn't really do it.
Reread all of this and wanted to see if you have checked the TPS to make sure the voltage is smooth and linear as it goes from idle to wide open throttle. This is a really good write up by Mike and in the first post you will see a referenced post by jrichker about TPS Setting and Trouble Shooting. Click on that and enjoy.
Yes thank you for this. The TPS on my vehicle is 0.72 v at idle or (KOEO) and if I open the throttle , the volts slowly increases . There is 4.25 volts at WOT.
Reactions: General karthief
Okay everyone whos been helping me on this. I have done a couple tests.
I performed an engine vacuum test,
a fuel pressure regulator test
and another fuel volume test.
The engine vacuum test shows about 18 to 19" at idle. I tapped into the vacuum T mounted on the firewall. The needle is steady with hardly any real movement.
When I hit the gas pedal real good, the needle immediately jumped to 0 and then rebound to about 22" and then settled at 17 to 18". I have a video clip of this but I don't think it will post here.
I then checked the fuel pressure regulator without vacuum line attached. It shows 42 - 43 psi.
Finally , I did a timed fuel volume test by holding the vent button on the fuel pressure gauge. I got a total of 252 grams of gasoline in 1 minute.
So , I believe the engine vacuum is good
And my fuel pressure regulator is working as its supposed to.
As for the fuel volume, it stills seems less than what it should be. I'm thinking fuel pump may be worn out? I'm unsure.
Also, when looking at the engine vacuum needle, it's steady but slightly moving the Littlest bit between 17" and 18" . It's barely noticeable unless you focus on it.
