Engine Water pump back plate bolts touching timing cover?
dqureshi06
102
21
28
Virginia
As the title says, I wanted to know if any of you have experienced this while installing your water pumps and if this is normal or not. The two back plate bolts are touching the timing cover but the pump seems to be installed evenly.
I emailed LMR about this exact issue about 2 weeks ago. Those bolts are not correct. You will need to use your old ones. The new motocraft pumps are made in China and it shows. I have pictures of the bolts mine came with in my progress thread.
Or you can buy the same water pump from the local parts store, problem? Just take it back and get another.
LMR is a great place to deal with tho, best customer service.
Yeah they hooked me up with a coupon code for showing them this bolt problem. I wish their return process was more user friendly. Having to weigh and measure the box before they will give you a label is a PITA. They need to improve that whole process.
Reactions: nickyb
I went ahead and found my old water
Pump in the trash and used the bolts from the old pump, much thinner now.
Never throw anything away until the job is up and running with no problems.....Sometimes keep the old parts longer until you are sure your new parts are working well........
