View: https://youtu.be/fjpv5aj8EIo?si=Xx6mSmQV8fUz0mfR
The tuning is coming along. It was perfectly smooth at low RPM and was seeing 12.9 at WOT with excellent street manners throughout partial load. Then, without changing a thing, I do one final pull and it runs 13.5, and bucks any lower than about 11-12mph. Still not bad.
Tuning is both awesome and frustrating. I think I just picked up on what it might be. In the vid, the AFR shows in the 16s. Later this evening, in was in the low 15s. I might lean it out intentionally way down low, now.
Overall, the car is acting a lot better. I'm pretty happy overall.
@Willybill32 Funny you mentioned the bucking at low RPM with your E303 cam today. I just kinda sorta cured that. Your response mentioned that you don't jmhave any issue with stalling. What is your idle set to? If it's still ~670 RPM, that's pretty nice. When you set the idle higher, you're building in the buffer you already had on the stock tune.
