Just out of curiosity, why wouldn't you want a one way check valve also from the Valve Cover oil filler neck to Throttle Body hose?
The subject of the PCV
system could be an entire thread alone. The short of it is dirty air gets drawn out of the crankcase by that tube you just removed and sucked into the intake to be reburned. (The PCV
valve is only there to prevent an intake backfire from entering the crankcase that may contain gas vapors.)
That hose is connected to the intake
behind the throttle blade, so engine vacuum is constantly pulling on the crankcase.
The idea is to draw fresh air
through the crankcase. Not just to pull vacuum on it. So that fresh air has to come from somewhere. As long as the engine is creating vacuum, fresh air is pulled
into the valve cover by the tube attached to the TB in
front of the throttle blade. That air has already been drawn through the MAF so it is metered. It's getting burned too. It's just taking a trip through the engine block first. Keep in mind that valve cover tube is connected between the MAF and TB from the factory and needs to be that way after you install the Paxton.
When you do inatall your Paxton you'll remove the tube from the throttle body and cap the nipple because now that area will be pressurized (Boost pressure would pump into the valve cover and crankcase). Then that tube on the valve cover needs to get connected again between the MAF and TB but in a non boosted area. That is your SC inlet pipe.
On a centrifugal SC car boost pressure closes the PCV valve and your new check valve. During this time crankcase pressure builds. It can no longer vent through the PCV tube because boost pressure closed it. The only place is has to vent is out the valve cover tube that is plumbed into the SC inlet.
For that reason I'd sugest installing either a catch can or at the least a filter of some sort in that line. Your kit might come with a little fuel filter for that reason. If you're keeping it 5psi or so that should be all you really
need to do.
