Here is a template you can print out also. Obviously if your switching to the new style badges it would only be a “guide”
Sounds good. I hadn't seen anyone (at least in videos) need to do that so i was thinking i was doing something wrong or had the tool set up incorrectly.
On a side note, i really just need to get rid of these H&R Race Springs and increase the ride height slightly. I think that would solve some of my rubbing issues. BUT, i want to go Coilovers and don't have the cash to put towards those at the moment.
Thanks for the link but these springs are just too harsh for my liking anyways. Something i need to deal with eventually. I recall having the Eibach Pro-Kit on my previous Fox and it was firm but not too harsh. IF i don't go coilovers up front, i'll probably swap out the H&Rs for the Eibachs.
I will use a heat gun when I get into it more. I mocked it up on my front drivers wheel and as mentioned, couldn’t really get it to work right without hitting my caliper.Curious about that Eastwood roller. I need to get one and roll mine I'm just worried about the 35 year old paint. You using a heat gun on the paint to keep it from cracking? Looking forward to see how you make out with it.
That seems like a nice tool to have. I need to wait for warmer weather to roll mine. Still cold here. Just snowed today....wtf.
I was actually thinking of something similar, just putting my space heater pointed at the fender from a safe distance for a while. Not that it’s ‘cold’ in San Diego but at night it does get chilly so the metal is pretty cold.The alternate, alternate method = one or two 300-500 watt work lights.
You gotta be real careful with the heat gun. The lamps, placed at a safe distance, allow you to go mow the grass while everything heats up evenly.\
And of course... Nice and gradual adjustments on the roller.
Get the thing setup so that you can make full sweeps. Whatever is in the way; Get it outta there.
I feel that if you tighten the clamp at the bottom of the tank, that your leak will stop. Happened to me after I installed mine. Discovered a small pool under the car as you described. A little tightening of that clamp [see photo] fixed it 100%.noticed a small pool of liquid underneath the coolant overflow tank..
Awesome! Will do that tonight.I feel that if you tighten the clamp at the bottom of the tank, that your leak will stop. Happened to me after I installed mine. Discovered a small pool under the car as you described. A little tightening of that clamp [see photo] fixed it 100%.
