While i was under the car just holding the lower radiator hose cracked open letting it slowly drain, i was just looking around at everything. I noticed my passenger side end-link was just flopping around, i could physically move it up/down like 1/4" and the bushing wasn't even in the 'pocket' of the sway bar. I tried tightening it but realized i need the car on the ground, not jack stands. Is this a just tighten till tight or is there a torque spec for end links? Drivers side looked fine.
Does 6-12ft lb sound right? Thats what LMR has listed for the torque specs.
Edit: I should note that the end links are new and seem to have poly bushings. The slop isn't from like bad bushings or something, its physically not tight enough.
