Slap a couple of these on there and the paint and body work are [done]!
Follow me for more great recipes!![]()
Take a mileage reading before they pick it up, I've been around transporters for years, most are great but CYA.
You're welcome.
BuellerTake a mileage reading before they pick it up, I've been around transporters for years, most are great but CYA.
You're welcome.
Wut chu talk'n bout Willis?Bueller
Both if possible without the driver knowing but not necessarily the truck, driver will prolly document with pics and notes on a condition report, I would be suspect if they didn't.Of the cars or their truck?
About all you can do with the the four lug stuff is good pads, flush the brake fluid, and drive it. I had the SVO/Lincoln Mark VII calipers up front long long ago and it was a minimal improvement that was not worth the hassle. This was with disc brakes in the rear so think Thunderbird Turbo Coupe rear brakes.
I will just put this out there. If you spend any money on the existing four lug brakes you are basically throwing money away other than maintenance stuff. Just switch to the SN95 five lug brakes which will exponentially improve the braking, wheel selection, and the parts are readily available in all parts stores. You can still find the cars in salvage yards and get decent deals to swap that way.
I used this kit from maximum motorsports back before I went to 5 lug. Comes with pads, shoes, braided brake lines, and caliper sleeves.
Brake Upgrade Package, 1987-93
www.maximummotorsports.com
Good pads, shoes, and braided soft lines make can make big difference even on stock brakes. Good tires too.
