Not trying to be sketchy so I’ll see what’s on there and just match the passenger side.
Either way I’ll be buying a ball joint press tool.
I checked my existing ball joints, they look to be the SN95 ones:Why not just get the loaner tool from the auto parts stores? That’s what I did back in the day.
Ordered a MM 4-point K-Member brace (the convertible one, MM website says it works with hardtops as well and has more ground clearance than the hardtop one - not sure why they even have two if thats true), and some poly rack bushings.
Good point.Possibly, deep oil pan and exhaust clearance "things".![]()
Did I read that without the spacer the nut runs outta thread before they torque down?
Or was that a dream![]()
From my research, if you run a fox ball joint with 94+ spindles without a spacer the castle nut will hit the ball joint taper (end of threads) before being able to tighten down all the way.I believe what happens is the castle nut goes so far down that the cotter pin hole it too far above the nut for it to be of any use. Small safety concern I guess...
Maybe look at someone that may have 3D printed one and shared the file?Anyone know if they make a good looking dual gauge pod for 2 1/16” gauges that isn’t the a-pillar? Below the radio bezel I can only find a 3 gauge pod. The A/C vent has a dual, but they are for 2 5/8” gauges… maybe I need to return mine and get the 2 5/8” gauges?
Good idea. I do have a 3D printer so would just need the .stl file.Maybe look at someone that may have 3D printed one and shared the file?
