TFI. PIP either works or it doesn’t.
I often defer to Aero because he's almost always right but I've had an intermittent PiP before and seen it a lot in these forums. If I recall, I used
@Mustang5L5 's how-to thread to rebuild my distributor with OEM parts (but I can't find the thread, ATM).
Here is a list of things you can check:
– Dump the codes (KOEO / KOER).
Use a paperclip/test light or a scanner on the EEC-IV port. Even if the Check Engine Light is off, codes may be stored. Pay attention to ignition-related codes such as 14 (PIP circuit fault), 18 (IDM circuit failure, ignition module or wiring), and also check for 96 / 87 / 85 which are fuel pump or EGR related.
– Watch the Check Engine Light when the tach needle jumps.
If the CEL flickers at the same time as the tach, that’s a strong sign of a PIP or TFI (ignition module) issue.
– Inspect the TFI module (ignition control module).
On a 1993 Mustang GT/Cobra, it’s mounted on the distributor. Heat or age-related failure is very common and can cause tach spikes or misfires. Check the connector for corrosion or loose pins. If it’s the original TFI, replacement is often the fix.
– Check the PIP sensor (inside the distributor).
The PIP provides the timing signal for both the tach and the computer. A failing PIP can cause erratic tach readings, stumbles, or intermittent stalls. Testing it properly requires a scope, but if the distributor is original and has 30+ years on it, the PIP is a likely suspect. Many owners just replace the whole distributor.
– Verify grounds and connections.
The tach signal comes off the TFI module’s IDM circuit (tan/yellow wire). Weak grounds, especially the small black/orange ground wire at the back of the driver’s side cylinder head, can cause erratic signals. Clean the salt-and-pepper connectors, the TFI connector, and check wiring to the ignition coil.
– Check the ignition coil.
A weak or intermittent coil can cause small misfires (slight power loss) and tach blips. Measure primary resistance (0.3–1.0 ohms) and secondary resistance (8K–11K ohms). Replace if out of spec.
– Do a fuel delivery check.
Even though ignition issues are more likely, low fuel pressure can also mimic a surge or stumble. At the fuel rail, you should see about 39 psi with the vacuum line off the regulator, and about 30 psi with it connected.
– Road test while monitoring.
If you have a scanner or logger, watch PIP/IDM signals during the tach jumps. Without that, you can try a wiggle test on the distributor and TFI harness to see if the issue shows up.
Most likely culprits in order: TFI module, PIP sensor in the distributor, ignition coil, wiring/grounds, and lastly fuel delivery. Dumping the codes is the first step because it may point you straight to the problem.
