Fuel FMU stuck?
JD1964
there is enough sticking out to grab on to
3,481
1,571
194
Maryland
The LX had been running great for a couple of months after putting the blower back in service. I was just about to increase the boost a tad with a pulley change but something happened. Shortly after a smidgeon of spirited driving, I noticed a rough and surging idle at the next traffic stop. I look at the wideband and its pegged rich, like 10. I'm guessing the FMU valve got stuck. Is this common? It's a Vortech FMU. I have not yet tried to start it again since limping it home. I wonder if after cooling down it will pop itself back into order.
I have never heard of this before but it should not dissuade you from checking it out.
What [is] common is a hole or tear in the diaphragm that gives the opposite issue... Not enough gas.
Thing I might suspect at the start:
Fuel Pressure Regulator - These can and do fail closed
Vacuum lines
FMU
Return lines
Dead cylinder (for whatever reason - spark, fuel, etc.) - ECU senses free air causing ECU to enrichen others in the bank.
Leaky injector - Most dangerous because one cylinder burning [fat] can make the EEC lean out all others in the bank.
I'd put a fuel pressure guage on it. Then you can see what's up as far as the FMU goes. You can also put a hand vacuum / pressure pump set to pressure and apply it to the FMU to see if the fuel pressure swings as it should.
You can rent a schrader valve FP guage from the local auto parts store if you dont have one.
Also pop the vac line off the FP regulator and see if it's full of fuel.
Reactions: JD1964
Thanks for the suggestions. First I’m going to start it back up today and see how it’s behaving.
I have a fuel pressure gauge and a vacuum/ pressure pump if needed for diagnosis.
For the record, it has a Kirban adjustable FP regulator. It’s been on there for several years. I did pull the vacuum line off and it was dry so I doubt the diaphragm is ruptured.
Reactions: nicholase
I found the problem. Duh! My cheesy bypass valve setup blew the hose off.
Reactions: Noobz347 and gkomo
I think I will change out the bypass hoses to a different configuration. My goal will be attempting to get the valve as far away from the hot exhaust as reasonably possible. Currently its pretty close to the header
Reactions: gkomo
Vacuum lines
FMU
Return lines
I replied to a thread from 2011, yes super old but when you see it and have time check it out plz. I guess I can just post it here but the questions are more relevant to the other OP's " Adding a Supercharger what else will I need" thread....
Ok I have the bypass valve relocated at least 4” farther away from the exhaust header. I have it wrapped with heat shielding fabric. I used 90 degree elbow fittings of stainless steel in both air pipes. It still looks cheesy but I promise you that it’s rock solid and won’t blow the hose off any more.
Reactions: gkomo
