Did I fry something messing with my ignition?
85gtCOBRA
23
Canada
New member here - on a mission.
'87GT
Was attempting to tap into the ignition coil for a tach signal.
I think i may have shorted something out (stupidly).
Here's where I'm at and what I know:
-Crank, no spark, no injector pulse
-12V at coil connector + (key in run), 8.8V (cranking)
-12V at coil connector - (key in run), 8.8V (cranking), no voltage change, test light does not flicker
-12V at injector harness + (key in run)
-fuel pump primes when key on
T.F.I. module
Module bench tests OK
Put a new one in for good measure (and faint hope).
-12V at power in (key in run)
-2.26V at start signal in :O_o: (key in run), 1.7V (cranking)
-12V at coil negative (key OFF) - not a typo, .22V (key in run) - not a typo, same to nothing when cranking ... WTF
-12V at ignition ground (key in run), 8.8V (cranking)
-8.8V at PIP (key OFF), .65V (key in run), no change when cranking ...
WTF
I don't even know how to interpret what I am seeing here.
Can anyone out there make any sense of this?
What do I even look at next?
By it talks to you are you getting codes? At a minimum you should get a Code 11 for all clear on the KOEO test.
Yes, I got code 11 and a fuel pump code (because i had it unplugged). Interestingly enough, after plugging that back in (at the inertia switch) now the pump runs continuously with the key on. Only change made so far is a new TFI module. Didn't really expect it to fix the problem but i put it in there anyway. Do those voltmeter and test light readings mean anything to you?
When the pump runs continuously that is usually an indication of the ECU :poo:ting the bed. Take a look here and work through the problem:
Reactions: OX1
Don't like the sound of that. I was doing diagnostics, taking readings, key on/off a lot when this first happened. Pump would prime and shut off as expected. decided to unplug it, no need for it to keep doing that every key cycle. only since i put the dist back in with the new module did it start doing that. This is a crap-show.
Update ... either the car is healing itself or my connections were not what they should be when i was testing earlier.
1. PIP out - 8.1V (key in run), 6.3V cranking ... this seems about right ... fuel pump primes when i ground the probe (as it should I believe
2. Start signal in 2.3V (key in run), 1.7V cranking ... clearly not what it should be - no change from before
3. Coil Negative - 12V (key in run), 9.3V cranking
For reference;
Could it simply be the coil itself got cooked?
The PIP is clearly sending a signal (of some sort) to the computer (fuel pump primes if I ground pin #6 with the key on)
Check voltages at the fuse links both sides by the starter relay in all key positions, and the one taped up by the firewall ecu plug, then check going into and out of ecu relay. The low voltage is either a failed switch, short or a fuse link that gave out. Car doesnt even need the ecu plugged in for spark. Your pip isn't getting enough voltage so no spark no injectors.
Anyone know how to turn this retarded auto correct off on an old fire tablet. Keeps jacking up what I type out.
Coils are cheap, but I've never seen a failed coil lose injection pulse, standard fd478 made in Poland coils is all ill run these days, too many are just repackaged China crap now.
Well, it's not that it (would have) failed on it's own ... I may have shorted it accidentally. So, potentially more violent than a slow death or wearing out. Pretty sure it was the coil it left the factory with.
I tested the red/blue start signal wire from the ignition switch to ground and got the same 2.26V reading as I got at the corresponding pin on the module. Does that mean the problem is in the switch?
If I understand, that start signal wire is just an alternate path (vs the run power wire) for battery voltage to get to the module (from the ignition switch). If it's 2.26V directly off the switch to ground ... what else could it be?
Make sure you have 12v into the switch, its fed by the fuse links, should be yellow 12ga wire if I remember right.
yes, 12V into the switch. both yellow wires. that start signal wire makes a bunch of stops ... neutral safety switch, ignition module, starter solenoid. starter solenoid is the final stop I think. pretty sure I've been thinking about this in reverse
The ignition switches have been known to fail and there was a recall on them. If its the original one I would replace it but that is just me. What transmission is in the car?
It's an auto.
Remember, not just a random failure. this is something i did - may have shorted the coil (connector) to ground. this is a super clean car, running near perfect before this crapshow (all me).
ignition switch looks really good (they fail physically i think - literally split apart. internally they are pretty stout, fat copper traces well separated).
here's the stops that signal wire makes:
It looks like that wire's first stop is the neutral safety switch, then it splits off and sends signal to the starter and the TFI module at the same time
