B bd101jc New Member Dec 9, 2025 1 0 1 San Bernardino CA Dec 9, 2025 #1 Dec 9, 2025 #1 How do I adjust my idle? Attachments 17653219372204753912344894930167.webp 317.9 KB · Views: 60
Noobz347 Stangnet Facilities Maint Tech... Er... Janitor Admin Dude Jan 4, 1985 43,364 21,571 234 Box behind Walmart Dec 9, 2025 #2 Dec 9, 2025 #2 bd101jc said: How do I adjust my idle? Click to expand... I've moved your issue into it's own thread. Make sure you subscribe to this thread to get updates. Because it was created by me, you are not automatically subscribed.
LILCBRA I wish I didn't have all of these balls in the air Mod Dude Dec 6, 2005 6,516 5,511 194 Corn County USA Dec 9, 2025 #3 Dec 9, 2025 #3 Idle is adjusted by a screw that contacts the throttle linkage. (This is a Holley, but they're all similar in this regard.) Be sure to thoroughly check for vacuum leaks as well. High idle is good indication that there is additional air entering the intake tract.
welder4956 20+ Year Stangneter Nov 28, 2003 251 116 53 Birmingham, AL Dec 10, 2025 #4 Dec 10, 2025 #4 Also, your photo shows an electric choke terminal with no wire connected to it. That could be preventing the high idle cam from disengaging. Reactions: LILCBRA
RaggedGT Been here over a DECADE and still no CT Mod Dude Jul 20, 2014 4,753 3,207 203 Taylorsville ky Dec 10, 2025 #5 Dec 10, 2025 #5 This’ll Fix it
LILCBRA I wish I didn't have all of these balls in the air Mod Dude Dec 6, 2005 6,516 5,511 194 Corn County USA Dec 10, 2025 #6 Dec 10, 2025 #6 RaggedGT said: This’ll Fix it Click to expand... Reminds me of this one.... Anti-Establishment Mustang II: It's No Pinto in Pony's Clothing Think you know what "dare to be different" really means? Try this on for size: an incarnadine equine with a blown V-6 in its teeth. www.hotrod.com I mean if you're going to do it, may as well, right? Reactions: RaggedGT
manicmechanic007 5 Year Member Sep 26, 2017 2,554 723 143 Roy, Utah Dec 10, 2025 #7 Dec 10, 2025 #7 There are 2 idle screws on your carb Main idle screw on the drivers side similar to the photo but that is a Holley and not your 2BBL Autolite carb 2nd screw is the fast idle screw under the choke cap on the passenger side of the carb
