It will reach that stage idling in the driveway but it will take a bit longer.
Update-
Just wanted to say that yesterday I actually put the OEM regulator on and when I switch the car on but no start the fuel pressure was 24 or 25. The car was still warm ish some from my trip yesterday and it was getting dark so I wanted to diagnose that quickly. Actually had an issue and I don't remember if it was me or the person who put the adjustable regulator on long long time ago when I was a rookie back in the early 2000s LOL. But the bolt hole nearest the intake was stripped and there was a bolt with a nut. I actually found the original bolt and fastened and it felt like it was getting decently tight but when I switched the car on there was a leak.
Anyway I got that all sorted out now and ended up having to use the bolt and nut and I just went ahead and put the adjustable regular to back on. Also to point out I put the distributor cap off of my other car which even though the car was used that sucker looks new. My rotor button looked fine but the MSD cap was not too bad but it did have some rust looking marks on it and I guess that's from age but it's not super super old but it might be old enough so I wanted to try it. Also had a couple of questionable wires where the metal clip inside the boot came off and so I just put on two of my old Ford racing wires and the car actually drives better so I'm going to end up getting a set of wires and a distributor cap and rotor button.
Now on to the checks for today. I could not check the voltage at the inertia switch by myself since I discovered you only get voltage for 2 seconds once you switch the key on so I started the car and the fuel pressure was 35. Vacuum was -5 and for some reason it seemed the voltage at the green wire of the inertia switch was 10.20 and the brown wire was 10.94 but that was using a safety pin which is a little bit difficult sometime to check the votes and you got to keep it still and don't let it move. The car when I fired it up it sounded like it wanted to cut off but it leveled out and I don't know I did prime the fuel pump 4-5 times after swapping The regulators to. I think since I've gotten it tuned when I first fired it up it kind of does that for a few seconds or so then levels off.
After a few minutes a few pressure was 33 and vacuum -9.
At about 140° the fuel pressure was 32 and vacuum - 11
At 180°. Still using the paper clip I got 9 volts at the brown wire in the green wire was 10.80 to 11 fluctuating. Fuel pressure was 32 and vacuum - 10. The car sounded more alive between 150 and as it warmed up good. (Definitely will monitor again tomorrow as I start the car and see if it sounds the same up on startup until it warms up).
Little past 180° the votes at both wires 11 plus to 12 and this is with pushing the clips straight into the harness connector without using the safety clip. That's noted for future reference to just try and use the connector from the meter if it will fit. The fuel pressure was at 31, 30 and vacuum - 10.
After a few more minutes for your pressure 29 vacuum - 11
Maybe after another 5 minutes or so fuel pressure 29 vacuum - 11, 29 then 28, 28 vacuum -12. Maybe after about 3 to 5 minutes fuel pressure 27 vacuum -13 and all of this is just sitting and idling vacuum - 12 to -13 at this juncture, fluctuating some. So - 14 and a fuel pressure 27, - 13 fuel pressure 26 and air fuel 14.20 ish. In my notes all of this is after 5 plus minutes running idling.
At 307 p.m. fuel pressure 25 vacuum -13 air fuel 14.50 to 15
At 3:09 p.m. fuel pressure 24 vacuum - 13 - 14
Leaving garage in until I get to the end of the driveway fuel pressure 25 vacuum -10 to - 11.
After taking off probably after a few minutes fuel pressure is at 21 vacuum - 17 at 45 mph air fuel 15-ish.
After a few more minutes of driving fuel pressure 23 vacuum -13.
After a few more minutes got to the stop sign fuel pressure 22 vacuum -14 air fuel 13.75
Pulled back into garage at 323 p.m. fuel pressure 21 vacuum -13 air fuel 14.11 at 200° on the gauge
Green wire 12 plus volts brown wire 12 plus volts
15 minutes later switched on not start after crimping the wires and uel pressure 22 vacuum 0 of course.
So it seems that once the car is good and warm the fuel pressure is much lower but I thought I read something as well where with a tune and if you are showing negative vacuum the fuel pressure is going to be lower something about there's a trade off or something I think I think that's what I read something along those lines where your fuel pressure is actually fine for what it's showing on the gauge according to what the vacuum is.
Thoughts?
