Ok guys getting my ducks in order for the 331 build for my 95 and have a few questions or one in particular right off the bat. The builder has the block and going to be getting some 4032 pistons soon. I've already sent him a lot of parts so far.
331 Stock block build
Holley Systemax 2 (more than likely since I've had a Performer 2 for so long on my other 302 setup and it's now on my Vortech '94)
Brodix 170 degree cc head with 1.94 and 1.54 valves
Custom blower cam
60 lbs ( I bought lightning 42's for when I was going to go NA so might sell them)
70 Tb
80 or 90 Maf ( Have a question about that )
1 5/8th Bbk LT's with an X and Spintech 6000's street pro
Mcleoud Super Street Pro I already bought for NA and hope it will hold up since looks like it's rated at 550/550 crank. I will likely be around at minimum 500 but I've seen a guy make 535 recently. It seems keeping the rpm's no more than 6k and a good tune and the block will be safe.
UPR boostmaster pipe
Vortech V3
255 walbro with stock fuel system
3.55 gears
I think that's everything and my first question is-
1. I have on my NA list go go with a 96-01 80mm meter and i can get it for around $35-50 vs $299 ish for an SCT BA 2600 90mm that I actually just put on my 94 setup.
If the 80 will suffice and there won't be any negatives having 10 less mm ( less hp lol), then I'll just go with it but if the 90 would be more beneficial I'll get it. I'm all about saving
money when I can and it makes sense.
2. I already bought the McCleod Super Street Pro and it's rated at 500/500 crank. My car will be a nice weekend street car only and I don't even horse them around all the time; I drive normal'ish sometimes believe it or not. So what do you guys think, you think it'll hold up? I have had parts now since early '25 and would hate to have to try and sell them. I already have to sell the black cold air tube I bought new and will be unused since I'll be going straight Supercharged vs running the setup NA for awhile first. I believe that's the only thing I'll have to get rid of that I won't need. After this build the only thing I might have down the road to do is when my 94's 200k miles finally dies, I'll do another engine for it but other than that that'll likely be the last build for the foreseeable future. I do plan on adding a fox to the stable but I will very likely buy one already built.
@Noobz347 @AeroCoupe
Hey Aero I know you told me about the 96-01 meter for Na and can't remember if you have a blower or not as I don't believe you do. But let me know your thoughts....
Custom blower cam
70 Tb
Vortech V3
3.55 gears
I want to say well I know he's well over 500 and close to 6 on the stock fuel rail so I'm fine.
