I dunno about you but I get that kind of mileage because of my foot and an addiction to blower whine.
I also think I run a little rich at cruise.
Well with a blower it justifies the hit on fuel economy because of the demand but on a NA set up it is not justified specially when I tried different styles of driving, that is going easy on the throttle or being aggressive doesn’t make any difference too much fuel gone.I dunno about you but I get that kind of mileage because of my foot and an addiction to blower whine.
So are saying that if I unplug that thing will only affect me during startup and the MAF and computer will disregard the signal from this barometric pressure sensor? Now I’m more confused…In your case, it only registers ambient air pressure during startup.
Ok I got you,It references air pressure at startup so it knows which cold fuel table to go to.
Once you're warmed up and in closed loop, the HEGO and other sensors make that determination.
Is not a guy, it is a compilation of postings regarding a specific subject and AI makes a suggestion based on those inputs.Who is this AL guy giving you that info?
Ok but the two sensors with different part number send different frequency signal enough to require me to have the specific sensor for my 90 GT with manual transmission or it doesn’t matter? Do I have the wrong sensor?There are different part numbers however, I converted to MAF from SD and am still using the same MAP/BAP. The only difference for me is that the vacuum line had to removed so the sensor is in open air.
Who has access to that garage?Not a chance, my ride stays in a closed garage.
Thank you
Your injectors aren't causing the poor MPG issue. Something else is causing it.Well apparently those two BAP sensors are interchangeable so what else could be causing to affect my fuel economy?
I’ve done everything I know and all that was suggested and I see no improvements.
One thing that I still don’t have too clear is with regard to my injectors. How could it affect my MPG if I’m using 19lb? Are they maxed out and are over fueling?
I’m running out of options here
