Hi, it's me again.
Last time I was here I posted about a spark plug blowout problem and consequent overly rich fuel delivery issue that I have fixed with the help of you, the community.
I have a new, very intermittent problem
When driving over bumps, particularly ones that are hard (I have a lowered car with stiff suspension, so hard can sometimes be bumps that are nothing for you) there is a very random chance that the engine will shut down, with an equal chance of randomness in the gauge odometer going to all dashes (--------). Sometimes in this intermittent issue the engine will shut down but the gauge cluster acts normal. Shifting to N and cycling the ignition works to get the engine started in motion again.
The only DTC I get when pulling codes with Forscan is a U1262, and the only advice it gives is to "run self-test" and "fix all relevant DTCs then clear codes and retest". Not particularly helpful in helping me figure out where could this problem stem from.
Any ideas?
Any ideas?
