Fox Xtremely high fuel consumption
Well I haven’t found that evidence yet.
About your last paragraph if I’m wasting over 50% of the fuel we are talking more than 7 gallons of fuel… I haven’t inspected both fuel lines from the engine to the tank it would be evident to see 7 gallons leak but in good fate I will lift the car to go underneath and will closely inspect all the fuel lines, I promise that ✋
The fuel lost per mile would only be maybe .05 gallons, or .2 liters per mile. Seems like a small drip somewhere that could be exacerbated by increased flow when cruising might be a likely culprit. Has the fuel tank been dropped recently? I'm wondering if it's leaking at the lines coming from the pump, like maybe a bad O ring or something. I think it would be possible to not notice a leak back there if it's not dripping to the ground, though I'd think you'd be able to smell it. I suppose it depends on where it could be leaking - it might be leaking on something and evaporating/burning off before it hits the ground or creates an amount large enough to notice. This is all a spit ball of course, but it does seem logical.... :chin
Reactions: PonyGTrider
Run those new set of plugs for a tank of gas and do your usual calculation to see where you're at.
You'll get a better read on the plugs too.
Wow... The length comparison in your image makes them look really long.
I can do that,
At first I was very concerned about the plugs coming in contact with the pistons but I measured that gap and relaxed then since there was over 0.200” of clearance
Yeah I know what your saying and I will do what you suggested
HERE IS AN UPDATE:
Ok guys here brand new NGK FR5-1 sparkplugs calibrated to 0.054” with about 8 miles with few springs at WOT with 84 octane gasoline 19lb injectors, 210lph fuel pump, fuel pressure at 39psi with vacuum hose connected, and 14 degrees BTDC of advance.
Let me know what do guys notice as far as air/fuel mixture? NORMAL, RICH, or LEAN condition? Any indication of over fueling as to cause a pathetic 9.5 miles per gallon???
Please I’ll read all your comments IMG_6685.webp IMG_6686.webp IMG_6687.webp IMG_6688.webp
You’re right I haven’t inspect the lines inch by inch and I’ll do that,
Thank you
Fuel pressure should be set at 39 psi with the vacuum line disconnected and plugged. It should read lower with the vacuum line on.
That would be with a stock engine and stock cam wouldn’t it?
Fuel pressure in my engine runs at 40+ with vacuum off and with my stage 1 cam only drops to ~39 with vacuum line connected.
Am I doing this thing wrong???? What do I supposed to have my pressure set with my set up???? All my specs are in my signature or profile
