On your last paragraph I think the resistors are just to keep the check light off and one thing I’m not sure how it works; does the computer disables the EGR function if the pint is static? (No vacuum hose or by way of resistors plug)
I heard that when the computer sees no activity from the EGR it registers as “non operating” and disables that function, but only if the check is blinking? I’m confused about that whole sequence…
They way it works is the EGR resistors mimic the signal that the EGR position sensor would send to the ECU and, in this case, send the signal the EGR is closed.
The ECU sees the signal and logs a code. I forget which one it is but it’s an EGR stuck closed code, or some wording along those lines.
The ECU then disables the EGR function. No timing or fuel adjustments. But the code generated doesn’t display the CEL.
You don’t need the resistors at all. You can just unplug the EGR completely, and the ECU will see this and set a code and also disable the EGr function. But it will trigger the CEL.
