Progress Thread 12th Owner: My '93 Notchback Restoration & Performance Build
You need to check those two slim head bolts. They look too thick to me. Looking at the timing chain cover it looks like the driver side one it contacting. I can see it on the bolt head as well in the second picture.
Reactions: Noobz347
What do you think of this close up? They're definitely tight, but I don't see any rub marks.
Since determining the Trick Flow Box R upper intake is not compatible with a stock height hood, I'm leaning toward having my Trick Flow Series R upper extrude honed. I already received a quote from Extrude Hone AFM in the greater LA area, and from my research this looks to be worth approximately 2-3% in increased power. Does anyone have experience with this process? This will likely be my last mechanical mod as my car is making approximately 402 at the rear tires and I want to keep it NA, but obviously 415 rwhp would be better.
Dudes used to get Cobra, GT-40, and Explorer plenums, extrude honed all the time.
They usually clean up the ports by hand, hook it up to the machine, and push abrasive Playdough through it until they get the inside diameter they're after.
Reactions: Habu135
Tracking. Just wondering about gains. I've got a tune already scheduled for 3 July. So either way I suppose I'll be reporting on it.
Most definitely blew the water pump gasket. And thinking back for the past few days, l do remember a slight leak ever since initial engine install by my mechanic.
Any suggestions from you all how to reinstall this securely so I never have to deal with a leaking water pump again is much appreciated. Stuff like, dry install or add some sealant? Thanks
Those bolt heads were contacting what, the WP? Caused an issue?
