The kit is great of you need one stop shopping, but you can likely grab all those parts, except the manifolds, from RockAuto for cheaper. They are pretty much the same brands they sell.
Accumulator will frost up depending on ambient conditions and this could be considered normal.
If you suspect your evap core is compromised, or even dirty internally, replace it. Would hate to see contaminates go downstream and plug up other components. Since AC work is expensive in general it's best to take an replace all approach to have the best luck of success.
I have seen folks remove the evap and flush it. You can certainly go that route to, but since it's out it wouldn't be a bad idea to replace it either.
out of it and break it loose.
