I tried to clearance the banjo bolt, but I'm afraid to go any further. I can still crack it loose, but if I take anymore off, I don't think I'll be able to service the brakes... It's very, very close but still contacting wheel.
Post in thread 'Black Jack: Weld Draglites. I guess I'm hosed' https://stangnet.com/mustang-forums/threads/884727/post-9385485Not to be ignorant, what is the current brake set up you need to clearance.
Are you running Draglites?This is the reason I am running non Cobra brake set up, with 15", plus lighter.
As for rear suspension bushings. I split a set at the track years ago. I switched to TeamZ solid set up. If you are launching hard with higher HP I feel solid is the only logical long term solution.
Was when 4 lug with factory drums and Lincoln front calipers I was on Draglites. Now it is 5 lug with Billet specialist 15x10 rear and 17"x5? out front.Are you running Draglites?
