dead spot (loose) in center of steering wheel
JTD2001
Texas
Today while driving a dead spot has developed in the center of my steering wheel mid-drive. My steering has had no issues whatsoever for the entirety of the time that I've owned this car (1999 Mustang GT). There's about a 1-2 inch dead zone in the steering where my wheel can turn but there is no turning in my actual wheels, so it feels as if my steering wheel is almost floating. The issue persists even when the steering is locked after I take the key out but it's probably only about an inch wide instead of two. What would be the potential causes for this issue, especially if it just abruptly happened while I was driving? I also had the outer tie rod ends replaced a few months ago with zero issues until today.
I would double check the tie rods just to be sure something did not come loose. I would do a sanity check on the wheel bearings as well. And lastly, I would take a look at the steering shaft/coupler assembly that connects the column to the steering rack. Those can get some slope in there from wear. Oh, also check the steering rack bushings. Hope you figure it out......
Hey I know this is 3 years later but did you figure this issue out? Mine did the exact same thing. Never had an issue then all of a sudden have a crazy dead zone and it has zero resistance, just bouncing back and forth. Would really appreciate it.
