Help with manual conversion
So i picked up my 89 fox earlier this year as something to just play around with. It came with a carb'd 347 with a c4 trans in it. Now from looking at the car, it looks like it was originally a 4cyl 5 speed car and the just cut the wire harness out of it and made it like an old school no frills car.
I am wanting to swap it over to a 5 speed as I'm not a fan of the auto that's in it. I'm not real familiar with mustangs as I've spent more time building jeeps so don't really know which year's are best for doing this type of swap. Are there years to avoid or ones that are easier to swap in it? I know I'm gonna have to get a flex plate, bell housing, pressure plate and clutch, and all that stuff. Just not real sure on main trans part and which one to get.
Thanks for all the help. Looking forward to tearing more into this car and actually getting it out and driving it.
Reactions: gkomo
T5 swap with OEM parts is definitely going to be the easiest and cheapest way to go. If you can find a crashed or roached out 5-speed V8 parts car for cheap that's probably the route I would take, you'll get everything you need in one shot and it will make your life easier. I used a crashed 1989 GT for my manual and 5.0 swap into my (formerly) 4 cyl 1993 LX hatch.
If your car started life as a 4 cyl car I would also check to see if you have the stock 7.5" rear axle or if the last owner upgraded to the 8.8" rear axle. If you have a 7.5" that is another reason in favor of picking up a parts car so you can swap over the rear axle and rear brakes.
I believe any V8 5-speed car that is 1986 and up has the upgraded world class T5 and an 8.8" rear end.
Reactions: Noobz347
The 8.8 started in the 1986 V8s. The V8 WC T5 was rated at 265 ft lbs up to the end of '89 model year. The 90-93 V8 T5 was rated at 300 ft lbs. These are factory trans numbers, not the T5Z or other upgraded T5s.
If you change the input shaft and bearing retainer you can use a 94-98 V6 T5 (rated at 265 ft lbs, same as the early V8 WC T5s) or the 94/95 V8 T5 (rated at 300 ft lbs) or the 99-04 V6 T5 (rated at 300 ft lbs - same gear set as the 90-95 V8 T5s). To not change the input shaft and bearing retainer you will need the hard to find 94/95 5.0 bellhousing - it is cast 5.0 into the housing. V6 bellhousings after 94 were cast 3.8.
TEST ON FRIDAY
Just me but while I was doing this I would install an aluminum clutch quadrant on the clutch fork.
I have a complete T5 swap listed in the classifieds and would consider shipping. You would need:
- A clutch cable so I would suggest either a Steeda adjustable or an OEM one with a fire wall adjuster. When I say OEM I mean new old stock (NOS) as the aftermarket non-adjustable units are 99% trash.
- Flywheel & flywheel bolts (would suggest ARP)
- Clutch pressure plate bolts (again would suggest ARP)
- Pilot bearing
- Bell housing to engine block bolts (good Grade 8 bolts with hardened washers is what I use)
You may also need a VSS to get the Speedo to work. Not sure if the C4 uses one or not.
You would also most like need the NGS wiring harness but not sure with the car being carbed and you would need the reverse light switch harness.
Not sure if the drive shaft you have will work so you will need to do some research there.
Reactions: Shakerhood
