Engine ECU Question
I'm the original owner of an 89 5.0 LX, 5 speed. It has low milage, but as I'd like to keep it for a while, thought it would be a good idea to accumulate some spare parts while they're still available. One of these spares would be an ECU. The original part number is E9ZF-12A650-A2A. Some vendors have these, but they're over $700. I've found another less expensive one with a part number of E9ZF-12A650-AA. Would anyone know if these are interchangeable? Thanks for any help.
I had that same mindset and not for over 4 years the spare sits in a guncase along with a tuning chip installed......LOL
All I know is that from what I read both ECUs are both A9L...
I have 3 A9Ls. One is my original, known good spare on the shelf. Two has a Quarterhorse plugged in. So, I can just plug and play it into the stock harness connector and tune any car I want to. 3rd takes a J3 chip and it's what I use daily... at least in theory. I never took my quarterhorse one out of the car. Still plan to... eventually.
Reactions: General karthief
I recently took a closer look at my spare A9L. It’s an original unrestored one. A couple weeks ago I plugged it in to the car and it worked perfectly. Although, on visual inspection of the board, I could see one of the resistors has a little bit of corrosion where it’s soldered to the board. That greenish crusty stuff. I guess I should swap it out for a refurbished one sometime soon
Someone posted this on Facebook the other day, still ran with an idle surge.. Imagine paying the stupid asking prices for a " factory sealed" one and cracking it open to find that lol.
  • Wow
Reactions: Mcmahst
That looks rough. More than just capacitors corrosion. That thing was left out or it went under water at some point. If it was costal I suppose salt air could do that too.
