90 mustang no spark
djj62478
53
Nj
Im going crazy here, I was having surging issues and finally got the car somewhat straightened out and now this. I somehow lost spark, it started when I noticed the rpms jerking up and down sporadically causing the car to want to die out. Sometimes it will run when cold and die and not start back up when hot, other times it won't start at all. Checked a plug from the coil wire to a ground with nothing. Tried a new coil with no luck, got a used good distributor(or so I was told it was good didn't know for sure) it actually got a little better after I installed that but then reverted back. I ohmed out the tfi, then the tfi plug with a light tester, ohmed out the coil, all testing good. I thought maybe the thermal paste on the tfi dried up and that's why it ran when cold but not when hot. Unfortunately the tfi I ohmed out to be good that I put on the distributor to test well now theres no spark so I can't even test that theory.
So here's where I'm at. I tested everything I can think of. Grounds, coil is new and tested good as well as the old one, 3 different used tfi's which ask tested good, 2 used distributors. Restabbed the distribution multiple times. Finally I put on the original distributor and got a new cap and rotor, I got spark off the coil and off the number 6 plug after plugging the coil back in to the cap. Thought I was good to go. Well I go to start it and it doesn't start again, I was finally able to get it started by keeping my foot on the gas pedal to the floor and then working the throttle to keep it alive. When I tried to let it idle the rpms were super low and the tach would sporadically jump around until the car stalled, unless I started working the throttle to keep it alive. It also is not revving cleanly. I'm at by wits end and don't know where to turn next, I'm guessing computer? I know I'm using old parts to try this stuff I just hate to go and buy a new distributor for it not to work, a new TFI, then a new computer, new ignition switch, I just don't want to spend all that money to throw new parts at it when it could be something I'm overlooking. And honestly it all started when the car was still running fine but the tachometer started jerking up and down to the point it would cause it to stall sometimes, but even with that happening you were still able to drive the car, then it just got progressively worse
You seem pretty able to do your own troubleshooting so I'm going to put this here:
I see there's been some part swapping so, assume nothing and go step-by-step. Ask questions if you get stuck.
One of our members recently put the [No Start] checklist into pdf form.
You will find that here: https://stangnet.com/mustang-forums...stangs-model-years-1986-1995-pdf-version.112/
It's printable so, easy to take out with you if you prefer that over a phone or laptop.
I would also start looking for a known good ECU that you can try but run through the list first.
Just tried a good ecu still no luck. It will sometimes start when cold and run for maybe 3 mins to 5 mins then won't restart or it will try but your foot has to be too the floor. I checked for spark again after installing the new computer with no luck, and again I'm getting spark off of the coil it seems but when I pull a spark plug off of the cylinder and try it grounded I usually only get one spark then nothing or very weak spark
I think the checklist is your best chance for discovering the issue. But, it seems the issue is heat related. Those electrical connectors expand under a heat load, making anything that is just making it work, not work. For what it’s worth, I would pull apart every single connector under the hood even remotely connected to the ECU and check each pin, expanding the male pins and tightening the female pins. And I would clean each, and apply dia electric grease to each. Now, that may not fix it, but it will be of value going forward. Good luck; I hope you find the problem.
I also forgot to mention it I think I did that my little fuel pressure gauge that's attached to the fpr is dropping pressure. For instance with key on only I can hear the pump the pressure jumps to about 30 or so the immediately drops to 0. Is that normal or would this be part of the issue
  • Wow
Reactions: Mcmahst
Did you check the ignition switch? Go under the column and make sure its tight and secure, a new one is only $20 bucks. Or just use a zip tie.
You gotta rule out one thing at a time,I know its fusterating as I've gone threw it.
Yes on checked the regulator vacuum line for fuel and it's dry, it's an accufab adjustable fuel pressure regulator with a intake 255 l per hour fuel pump that's brand new. Nickyb I replaced that ignition switch a while ago before I even got the car running because it was cracked but I know there was a metal clip or retainer that it came with it and never went on, so maybe that's the problem maybe that thing holds it in place and it worked it's way loose? Will that switch even cause the issues I'm having or just a complete no start?
